Mavic 2 props on mavic pro
careless
KENTUCKY USA.
I mistakenly ordered M2 Pops for my MPro and was told that it wont work but I watched a video and they worked so now I'm confused and hope to be able to return the props if I have to. Has anyone tried this?
They work great actually but you have to kinda trim the very ends off of the rear props so that they don’t hit the tail of the air craft. If you put them on and spin them with your hand they don’t even hit but I guess they get kinda flattened when rotating. At any rate they are great props for the M1 and the very ends are just winglets they don’t provide lift so you aren’t handicapping them by trimming
i have an mpp and a m2p the props from the mpp will fit on the m2p but not the other way around the m2p props are slightly longer and will hit the mp in the rear
Reactions: careless
i wouldn’t risk that for one the props are what $10 bucks the drone is $1000 there abouts if you trim them you could split the end of the props and not notice an issue until the drone comes crashing down
Not only that but you can not be absolutely sure you cut off even two blades exactly the same, let alone 8. Therefore you could have a serious imbalance problem between the four motors and that could damage a lot of things. Just sell what you have and order new ones that are correct, or swap them out with the supplier, but don't listen to people telling you to cut the tips off. Don't do it.
SGTMEZ
