Mavic 2 zoom problem IMU
rino99
Italy
Hi to all, I bought a new wonderful M2 zoom, but from the first switch on, I got a warning to calibrate IMU. In the menù I found ACC2 Data error. I done calibration without result. The firmware is the last one.Tried to fly and the M2 is quite ok but still have this error. Do you have some suggestion or I have to contact support?
I think you must change IMU Module because it's mostly the cause of the problem
This piece is connected to the GPS board at the bottom of the board
I run into a similar issue with my Mavic Air a while ago. A good old fashioned whack fixed mine; yeah seriously! I am not suggesting you do the same but here is the thread if you want to take a look
They probably sent you a new or refurb rather than actually repairing it. Check your S/N when you get it back. If different and you have refresh, be sure they transfer the refresh to the new S/N.
I think they repaired mine....but I'll check the serial ....yes I have dji care refresh.
I think you're right, I'm trying to check the DJI REFRESH CARE with my serial number but it gives me an error ....I wait next arrive....
dvkhamtruocsinh
