Mavic 2 Zoom Replacement legs. Not the arms
If you are talking about the "stock" legs that come on the drone, they come as an assembly, motor, wiring, and LED's. The front legs also contain antennas in their extended foot. Back legs are similar but no antenna. Front leg assemblies run about $45 and back ones $35 (this does not include the hinge and bushing thingies - they're extra.
If you are referring to the clip or slip on extended legs, so the drone can on the lawn etc, they are available on-line.
All are available on Amazon and from other sellers on-line.
I think the OP is referring to the long 'feet' on the front arms that house the patch antennas. Held on with three screws to the underside of the front motor housings (and one tiny screw BEHIND the front LED's)
Found one.... Thank and way cheaper then 35 dollars!
There are many of these out there that are aftermarket and will be slightly off color and texture. Please post back what you ended up with.
Thanks.
Dimension Drone AZ
