Mavic 3 Pro Cine Dimensions
prosmart
Brisbane, Australia
Greetings
Looking at buying a combo kit locally of the Mavic 3 Pro Cine when it's released here next month and I'm looking for a hard case to suit.
Because this model is so new there do not appear to be any cases around specifically for the Pro model yet.
I don't want to order one for the Mavic 3 and then find out the Mavic 3 Pro Cine does not fit in it.
Can anyone give me any info or suggestions please?
Thanks
Nigel.
@prosmart the main difference between the original and the new pro version ,dimensionally , is really only the camera ,i would expect that the well known case manufacturers, will soon be on the case (pun intended), and will supply a modified foam insert to accommodate the new version
Reactions: prosmart
Looking at buying a combo kit locally of the Mavic 3 Pro Cine when its released here next month and I'm looking for a hard case to suit.
The cine version will be the same dimensions as the non-cine version.
But it will be a little larger than the original Mavic 3
Original:
Folded (without propellers) 221×96.3×90.3 mm (Length×Width×Height)
Unfolded (without propellers) 347.5×283×107.7 mm (Length×Width×Height)
Mavic 3 pro
Folded (without propellers): 231.1×98×95.4 mm (L×W×H)
Unfolded (without propellers): 347.5×290.8×107.7 mm (L×W×H)
The standard cut-out cases are usually a snug fit and you'll be better off waiting for one made to fit the 3 pro.
Just watch ebay or drone shops and they should be available fairly soon.
I see a few on ebay today now.
Yesterday there were none.
kholik ibnu
