Mavic 3 Thermal Testing Request
jaja6009
Part 107
Hello,
The question keeps coming up about if the Mavic 3 Thermal when using the RTK module can produce "survey grade" outputs.
There is a lot of differing opinions on this.
DJI's forum says, no, low centimeter accuracy is not guranteed.
DJI SDK says the TIme Sync is enabled though.
Heliguy's website says 25 cm RMSE.
Can somebody that owns a Mavic 3T and GNSS equipment please do a test?
Map a small area and only use Check Points and please post your results. No GCPs.
Also if someone is in the South New Jersey area, if you own a Mavic 3T, I can place the Check Points with GNSS equipment and you can fly the mission. I will process in Agisoft Metashape.
It is amazing that this sUAS has been out for over a year, and there is not one example posted showing this.
Too many people ask this question and there is too much conflicting information.
KenBrackin
