mavic 3 working 100% with errors
pangoloo
Brasil
My Mavic 3 has the code 40021 1c100204; 1c600204 However the drone is 100% What is the possibility of removing these errors without replacing parts?
Reactions: Cafguy
Did you replace a part?
The 40021 error shows you have a new part or parts (the ones you replaced) that do not match the numbers on the Main board. DJI matches numbers with specialized software called Repairtool. It can only be used by DJI. However there are services out there that can serialize your drones parts for you for a fee. I will not recommend one tho but they exsist and will work for you. Your only other option is to send it to DJI, They will simply replace the drone tho (expensive!!).
The other errors were caused by the ESC However those could have been triggered by the 40021 error. Get your parts serialized and if the other 2 errors persist then your ESC needs to be replaced.
Reactions: pangoloo
I'll look for information about serializing, since it's practically the only option
Thanks
Reactions: Cafguy
bostondronepilot
