Mavic air 2 compass error and ricalibration
mattitech07
IT
Hi guys , some days ago I've flown my MA2 a bit arund my house without problems,but when I landed it gave me a compass error,I didn't give much weight to it ,so I just turned off the drone and decided i would recalibrate it before flyig next time. A day later I turned the drone on in idle to check some files and the compass error was gone and everything looks normal.
If it doesn't give me the error anymore,does it mean it was just a momentary error and I don't have to recal,or should I do it anyway ? Becuase to recalibrate I have to walk till the field close to my house ,so there are no interferences.
it gives a compass error message when there is something causing it
but once the drone is moved to another spot away from the interference
then the error message goes away
this is quite normal ,but never just ignore the message ,as it could cause issues in flight
...If it doesn't give me the error anymore,does it mean it was just a momentary error and I don't have to recal,or should I do it anyway ?
In order to determine your crafts relative direction to the the magnetic north it uses a compass which measures the earth magnetic field. But this require that the compass can do it's measure without influence of other magnetic fields coming from nearby ferromagnetic objects.
The compass in your craft measure the sum of several magnetic fields in reality ... this as several internal components in your craft is ferromagnetic, and this sum will not be a good indicator of the earth magnetic field ... the compass will not point to north.
In order to "wash away" other interfering fields coming from internal components in your craft a compass calibration is performed. Plain & simple ... a compass calibration measure the craft's own magnetic field so the flight controller can deduct that from the total sum of magnetic fields ... leaving it with clean information about the earth magnetic field.
So a compass calibration is generally only needed if you have altered the craft's own magnetic field ... added or taken off any equipment from the craft itself.
A compass error is usually triggered when the measured magnetic field field strength sum falls out side a pre-programmed acceptable interval ... like if you place the craft near something ferromagnetic, like the rebar's just below the concrete surface where you place the craft ... or you hold your craft with the hand where you wear a big steel watch ... or place your craft just above a nail on a wooden deck ...
If you get a prompt to calibrate the compass ... always question that. Power off your craft & move to another spot instead, & power on & see if the prompt comes back ... if it's still there it can be motivated to do the calibration.
Then add below to your take-off procedure ...
Before take-off ALWAYS ... add in one very easy check to avoid a really scary event coming from accidentally launching from a magnetic disturbed place with following flyaway at height in an uncontrollable circular or straight flight path.
After powering on your drone, connected to your RC/app & placed it in the take-off spot ... but before lift-off, ALWAYS check that the drone icon on the map in your app is pointing equal in relation to other objects in the map as the drone does in reality ... if not, abort launch attempt, POWER DOWN & move away, power up again and repeat.
Reactions: mattitech07
It's unlikely that you would need to recalibrate the compass.
Although it sounds like a problem with the compass, a compass error would be more accurately called a compass warning.
Almost every time you get a "compass error" there is nothing wrong with the compass and it's a case of the compass warning you that you've landed or put it down close to something made of steel.
from what the compass is warning about and start again.
Wow,thank you for this detailed answer !
Reactions: slup
sscott062
