Mavic Air 2s /Air 2 double battery .7000mAh .4;mins of flight time. Price is £100.now sold sold
Status
Not open for further replies.
Craig Notts
Nottinghamshire
Made up of 2 original DJI air 2 batteries giving twice the normal capacity and 45 mins of genuine flight time. All telemetry work perfectly showing real time percentages. Just use in exactly the same way you would a single battery.
UK only
Can't post abroad
I have this shown on you tube demonstrating the battery.
I like it but 23volts ,34 min on stock which I'm sure makes things pretty warm,what's the extra goin to do to it,depending how its wired it can be 2x3s batterys or 1x6s ,,battery got 3 cells hence the 3s lipo,,,must be ok or it would have fried the avionics,,curious on you test though
Just add I run 2x11.1 volt 3s with a balance plug in rc boat that draws 40amps instead of a single at 20amp running though a 120amp esc,,,if I not use balance plug it goes 6s and would fri most components, and boy things get warm,like hot,,be interesting to see how it goes,,good mission though ,
UK only
Can't post abroad
Hello,
It's still actual? Can u link a youtube video link?
Status
RichardThiery
