Mavic air arm damage
R436
Hello all, so I had a run in with a power line. Everything appears to be fine except for the small piece of plastic that stabilizes the landing gear/ antenna does any one know if just that piece can be bought and replaced. Or do I have to buy a whole new leg?
well as it turns out it was a much harder hit then I thought and I have damaged some sensors. I think im just gonna send it to dji and have it repaired. thanks for the help.
For what it’s worth, thingiverse.com has plan to 3D print that part. It was a little tricky to install but with a little Dremel work I got it fitted. Leg does not snap into position but holds it position just fine.
After a recent collision with a tree my magic air rear port side arm is disconnected from the main body at the hinge point. Everything else seems to work fine and props engage on start up however the arm is loose. Anyone have any experience. It looks like it should just pop back on but I can’t get it to. Pic included for detail. If anyone has any advice, other than avoid trees, it
explorjus
