Mavic Air BMS bypass - B0BS: Battery without BMS FOR Mavic Air
nguyenmihung
vietnam
I tried to follow his diagram, but there are some errors that prevent the Mavic Air's BMS circuit from being unlocked by the hardware of the circuit. Can anyone help me in more detail on how to unlock the BMS circuit for mavic air with hardware?
Only 2 wires are needed to power directly from the 2 ends of the 3s-11.55v battery, remove the balanced voltage and replace it with a 10k ohm resistor. Next is to remove or add some components on the BMS Mavic Air circuit that I do not see in the video. He doesn't share it.
Can anyone share how do I do it next, let's build together.
Youtub - MinyC
Hack mạch BMS pin Mavic Air "KHÔNG bao giờ KHÓA" | Thử bay drone với bình acquy xe máy và cái kết​
Reactions: Naojinglen
I find this very good, we can install any Lipo battery to use and not be locked by this BMS circuit. Hope everyone in the forum together build this "Mod" bms circuit.
I have successfully unlocked the battery circuit for DJI MAVIC Air, you can use lipo battery cells or batteries with 3s 4s voltage as in the video above. If you want to refer to it, find me, share it for free for everyone to use.
droidboi
