Mavic Air Yaws Without Stick Input
JoelP
San Jose, CA
I have been flying my MA for about 1.5 yrs with virtually no problems, but it has suddenly started to yaw quite a bit when my hands are totally off the sticks. I checked the relatively new props and found them to be free of defect. I thought that this might need an IMU calibration, so I watched the video on how to calibrate the IMU. I started up the MA in Go4 and went to IMU to find it stating that the IMU was normal. I don't see any way to recalibrate this unless it thinks it needs a calibration.
I also ran DJI Assistant on my Windows 10 PC, thinking that there might be some sort of calibration there, but all I found was calibration for the vision sensors. I tried to run this, but was again unsuccessful. It recognized my MA, but failed to connect despite several attempts. I updated the driver and tried again to no avail. I uninstalled and reinstalled the DJI Assistant, but it still won't connect. For now I am less worried about this problem than the yaw issue, but sooner or later I will need to find an answer to that issue as well.
Have others experienced this yaw issue? How have you solved it?
Sounds like it might be a controller stick calibration needed.
Reactions: Bobvt
Thanks WWMav! That was exactly the problem. I had never thought about stick calibration, but in retrospect I should have figured there would be something like this. Now it sits rock steady.
Reactions: Thomas B and Bobvt
I was thinking it would be a compass calibration or magnetic interference on launch. That's a very common reason for uncommanded yaw as the IMU tries to agree with the compass. Stick calibration issue is the other common cause.
I had calibrated my compass just before noticing the yaw problem. When I tried to recalibrate the IMU it indicated that the IMU was normal and the option to recalibrate was not available. So glad that the stick calibration did the trick.
Reactions: Thomas B
I've recalibrated IMU before even when it was normal. It may tell you it's normal and not required when you do a check, but it still should have the option to perform the calibration. That was a while ago though so I'll have to check if that's still the case.
Huey0315
