Mavic mini battery
A mini 2 battery will NOT fit into a Mavic Mini.
The Mavic Mini's battery corners are more rounded and as a consequence the mini 2 battery's corners prevent it fitting.
From memory the mini 2 battery also has a slightly higher maximum voltage, whether or not that extra voltage would be dangerous to a Mavic Mini I do not know.
However, not that it helps you, a Mavic mini battery CAN be used in a Mini 2.
All true but... the mini battery will make the mini2 heavier
Thanks for that. I thought I had read that somewhere but couldn’t remember which battery would fit which drone
Mamanov Ramazan
