Mavic mini Two-Way Charging Hub work with Mini 2 Batteries ?
Patrick Bergeron
Montreal
Hello,
Do you know if the Mavic Mini Two-Way Charging Hub is working with Mini 2 Batteries ?
Since the batteries from Mini 1 is working in Mini 2, I would like to know if I could use my old charging Hub ?
Thanks
Actually the battery case is the same size but different shape. Rectangle peg in oval hole won't work, but oval peg in rectangle hole will. Pretty clever, and for good reason. MM1 charging would undercharge MM2 batteries as those with third party MM1 battery chargers can attest to, and MM2 higher voltage could damage MM1 AC.
MM1 batteries are lower voltage but MM2 charger is probably programmed to adjust to prevent overcharge.
Reactions: dulcificum
David H
