mavic pro gimbal fails after start up
dave canada
I ,ve installed all new cables ,video transmission ,gimbal contrrol board main control ,after a crash and it starts and i get the ready to go but the gimbal won,t work now what?maybe a powerboard
Just checked the prog(dji-firmware-tools) and yes it is also for the Mavic Pro.
The code for the Mavic Pro is WM220.
When you disassemble the gimbal you should recalibrate the Gimbal so that the camera is centered within its range of movement. To do this, if gimbal calibration does not work, you can try the dji-firmware-tools program.
There are two commands that need to be run, which for the Mavic Pro on COM port 3 are (Check your COM port number and edit as appropriate).
python comm_og_service_tool.py com3 WM220 GimbalCalib Jointcoarse​
and
python comm_og_service_tool.py com3 WM220 GimbalCalib LinearHall
Jointcoarse moves the gimbal to its extremities and saves the values.
LinearHall centres the camera between the recorded extremities.
Good Luck I Hope the following Helps.
Video Here!
DJ1 Mavic 2 Pro/Zoom GIMBAL CALIBRATION​
Tools .​
2. pyserial
GUIDE :​
1. Download all tools​
2. Install python​
3. extract pyserial and dji tools to C:\DJI\​
4. Open "command prompt" as administrator​
cd C:\DJI\dji-firmware-tools-master​
5. Install pyserial using pylon script​
cd C:\DJI\dji-firmware-tools-master\pyserial-3.4​
python setup.py install​
Turn ON Mavic 2 Pro/Zoom​
Gimbal Calibration​
python comm_og_service_tool.py com3 WM240 GimbalCalib Jointcoarse​
python comm_og_service_tool.py com3 WM240 GimbalCalib LinearHall​
WM220 = 14 # Released 2016-09-28 Mavic Pro (also includes Released 2017-08-24 Mavic Pro Platinum)
ahh thank you so much It will take me a bit but have been there before with the inspire I really appreciate this
and
Video Here!
Tools .​
2. pyserial
GUIDE :​
2. Install python​
Gimbal Calibration​
well that did not work soo i believe i have other issues like a burnt gimbal motor and i need to find that or were it might be becuase the gimbal moves side to side but the degree action dosen,t work at all
Sorry to hear that. Clearly it still has a physical fault, a connection or maybe a cable. I think that with the Mavic pro, gimbal faults are usually because of the ribbon cable.
Best of luck in finding a solution.
and
Video Here!
Tools .​
2. pyserial
GUIDE :​
2. Install python​
Gimbal Calibration​
I'm assuming you were talking about M1P, but you've switched to M2P. I think I've tried gimbalcalib on M1P and I get an error to the effect of unrecognized command.
tabarton94
