Mavic pro on Evo blades?
  • Thread starter Thread starter Deleted member 109911
  • Start date Start date
You say nothing to gain but that is how you learn to improve is by trying new things the reason i am curious the evo 2 is extremely quite so it is a combination of motor structures and blade design. I am curious if the design would enhance the abilities of the mavic or disrupt its stability. Example if you turn on the propeller cage function without propellers you will have a shaky mavic.
Reactions: kidroc
Why would you use Evo props designed for a completely different drone/motor/weight combination.
If you believe you have the answer to that please proceed as you feel best and report data/outcome to this thread.
Reactions: Kilrah
You say nothing to gain but that is how you learn to improve is by trying new things the reason i am curious.
... I am curious if the design would enhance the abilities of the mavic or disrupt its stability.
DJI have a team of propulsion engineers who have produced a tuned propulsion system with matched motors, ESCs and propellers.
The performance of the drone is governed by the flight controller, not by the individual components.
Do you think that slapping random parts on your Mavic is going to miraculously work better?
If you do, by all means go ahead.
Reactions: kidroc and SkyeHigh
Correct and also why would you use platinum propellers for a mavic pro. Some where along the way they were able to find a better more efficient design for sound generated and overall efficiency. I was just curious if the possibility of a more quiet solution. I thought this would be the place to discuss the possibilities not for a multitude of reasons why not do something that could potentially benefit the performance of the mavic. I went to college for art and design and attended school with the president of hallmark school of aeronautics. I am almost certain that there is positively no way to be 100% certain that the design that is used is the only one that is the most significantly silent choice. Perhaps they have a more quite design that doesn't meat the "27" minutes of flight time.... just thought it would spark some open minded conversation as to the potential of an alternative design. Fpv quads have a number of variations of props and each one shines for a particular reason. Speed, stability, freestyle acrobatics. I figured if those quads could have options why not the mavic pro?
Reactions: mereflyer
I think you are right to be curious about any alternative combinations that may improve our DJI products - after all how else is any real progress ever made?
I don't see any reason why someone should not at least be applauded for experimenting and reporting any results good or bad here in these forums.
I say Bravo DC for having a healthy outlook and foreword thinking - should be more of it!
Reactions: L o k i
So back to trying new things. Those people who are not apposed to getting inside the mavic pro. I purchased the replacement shell and painted it with bright white diamond spray reflective and glow powder added to clear top coat. No noticeable weight difference i did sand the pieces. But top coat is 2x and has made the body stronger than before. Check out the finished product.
So back to trying new things. Those people who are not apposed to getting inside the mavic pro. I purchased the replacement shell and painted it with bright white diamond spray reflective and glow powder added to clear top coat. No noticeable weight difference i did sand the pieces. But top coat is 2x and has made the body stronger than before. Check out the finished product. BTW I trimmed the mavic 2 props and not only are the deeper sound more quiet because they are wider i get better stability haven't even checked flight times but I am certain it is more than the its original props.
In most cases I’m a fan of trying new things but DJI has **** near perfected there lineup I highly sought you can find a prop that’s better than stock... By all means try it let us know how it went.
You won’t find a better overall prop, but you may find one that does better in a specific area, say less sound/noise. I used Mavic 2 master airscrew props on my platinum and made an already quiet drone even more so, but at the cost of more stress on the motors and a little stability in high wind. No full throttle up and forward, no sport mode and no high wind. I can give those up when I want less noise, or put the factory ones back on when I can‘t.
Let me rephrase that you won’t find a better prop besides master air screw props for the Mavic pro pro 2 but they are designed for them..I’m not a fan of the spark or the Mavis air versions.
Dimension Drone AZ
