Mavic Pro Platinum more Range more Speed ? (SuperPatcher not Worked)
trifft_nix87
Germany
Hi Community,
Quick question: I have a Mavic Pro Platinum again after a long time; I think the last time I used it was in 2018. All my knowledge stems from that time. My Mavic is on version 01.04.0500, which I believe is the latest version. I thought I could use SuperPatcher to activate the altitude limit and FCC mode, like I used to, but none of that works anymore. First, SuperPatcher complains that it wants Windows 10. Okay, I installed a VM, installed Windows 10, and started SuperPatcher 2.03. The copter is connected, but it's not loading any data; it just keeps saying "Connecting aircraft," even though it's connected.
Does anyone know of a working way to make the drone faster and increase its range using FCC mode that works like it did back in 2018?
Thanks, friends!
Did you Configure the VM. Try another port the O.G. Mavics are picky about that. VMWare or virtual box?
VirtualBox works, but it's recognized in DJI Assistant 2 and the NLD Mod Client. However, the NLD Mod Client no longer works because I no longer have a license. It's a different Mavic than the 2018 model, and I didn't want to spend another €40. I thought I could manually adjust the parameters that the NLD Mod Client changes via drag and drop.
With DJI Assistant 2 version 1.2.1, it works, but the FCC mode doesn't, and I wanted to use the Patcher for that, but it seems to have stopped working.
Reactions: Cafguy
you might browse the github forum you might find something there?
wang
