Mavic Pro Won't Take Off
qwefqwef
Problem? One month ago I had gimbal issues and replaced the ribbon to fix them. It worked, but when putting the drone back together, the vision sensors refused to connect (even after re attaching the clips several times), and then today I finally took it out for a test flight, and the compass wouldn't calibrate, I got repeated IMU initialization error messages (the drone had been on for 5+ minutes) when I tried to take off, and even manual take off would not work.
Was unit in a crash? yes, 2 months ago. No damage, and flew fine for 2-3 weeks after
What have you tried so far? I fixed the gimbal issues as previously mentioned, but today after this incident I factory reset and then updated to latest firmware, and the problems remained. I've reconnected the VPS sensors several times, and everything is plugged in properly inside.
What device are you using ( iphone , ipad, Samsung , etc)? iphone x
What firmware are you running ( aircraft, remote controller)? latest
What Go app version are you using? latest
Any modification?
none
Did you change anything or install any apps? none
Any help is very much appreciated as I hate having such an expensive brick.
djimini3
