Micro SD Capacity Indicator
Robert Granata
I just switched from android to iOS and am using an Ipad Mini 4, Go4, and all the latest firmware. The micro sd card capacity indicator stays stuck on 99:59 even after I have recorded 20 mins of 4k/30. I have reformated the card from the Mini 4 and it still it just says 99:59. The card is a SanDisk 64g U3.
Recording in 4K/30 should give you approximately 148 mins on a 64GB card. With that been said, I believe the DJI Go4 app (at least in iOS) shows max remaining counter to 99:59 mins. Once you have more then 49 mins of recording in 4K/30 store on that card, it should eventually come below 99:59 mins.
Thanks Pushpak. That makes sense.
camposbrito
