Mini 2 controller - strange issue - can be powered on only once per power cycle
petr22
Czech Republic
Hi, does someone have experience with similar problem, please?
Mini 2 controller can be powered on, but only once - works normally, control aircraft, firmware can be installed.
When turned off, it cannot be turned back on until both batteries are reconnected and USB-C charger is connected.
Then it can be turned on again, but after powering off, same situation happen.
It is same with only left battery, with only right battery and with only USB-C charger and both batteries disconnected.
It is not possible to RMA this controller, there should be logical explanation for this behavior. As it happen with external
power, I think it is not caused by one of the batteries.
Noexcuse
