Mini 2 fast charger
royp
Is there such a thing as a Mini-2 A/C (not USB) fast/quick battery charger that just charges one battery at a time? Thanks!
I ordered two of these and have been charging the single battery in the drone on QC. It is within the specs DJI wants and charges the battery in a fraction of the time. You can tells it's quick charging as the light sequencing speeds. Works much faster and we use the 2nd one to charge our iphone XR's. Fast and not expensive.
Even if it's not USB and is instead direct AC to contacts, it's still only going to charge at the same maximum as the maximum USB option (29W at most). This is a limit by the battery, not the charger.
The link Nestorosg posted, you'll notice the most that charger does on the USB ports is 5V3A which is the equivalent of the DJI 18W charger (though they don't specify if it's shared thru both ports, or for each port). The direct plugs being 8.8V/2A, is just shy of 18W again, equiv to the DJI's 18W charger when delivered at 9V@2A. Main advantage being multiple batteries at once rather than one by one.
I have an Anker USB-C rapid charger that's 45W (it'll vary depending on the device plugged into it, since it starts slow until it gets confirmation from the device being charged what it can do, such as PQ/etc) But I have not yet tried to use it with my Mini 2 2-way charger to see how much faster 29W does charge each battery one at a time.
The DJI charger supplied with Mini 2 flymore combo is 18 watts. The charger you quote is max 18 watts per USB port. So no advantage.
CMDR DV TEARDROP
