Mini 2 flight speed adjustable?
HomeBod
Ireland
I know you can adjust the speed of the gimbal, but is there any way to adjust the speed of the drone itself? There are some shots where I would like a slow movement forward, but no matter how gingerly I move the joystick, it seems to have a minimum moving off speed. Is there any way to adjust the sensitivity of the joystick downward, so I can get very slow forward speed?
Did you try Tripod/Cine Mode?
Yes, Tripod Mode is the slowest speed.
@HomeBod ,it seems that since the Fly Apps recent updates ,the way the drone responds in Cine mode has changed , I have the MM first version and when in Cine mode the actual speed of the drone as it is being flown around ,is not a lot different to position mode ,what has changed is the Yaw speed ,it is now very slow in yaw compared to Yaw in position mode ,and this has nearly caught me out a couple of times ,now if i am in Cine mode and use just Yaw to change direction the drone is very slow to respond in relation to the forwards speed ,and to get a tighter coordinated turn some combination of Yaw and aileron is needed ,in comparison my MPP when its in Tripod Mode all the control sticks have a very slow response effect on the aircraft and it is very easy to fly slowly in all directions
Drone-Hacks has speed settings for the Mini 2
Drone-hacks.com
M5P
