mini se battery cover stuck
danielcurran
malaysia
Problem? battery cover stuck can’t open
Was unit in a crash? no
What have you tried so far?
: prying out the cover with a coin and finger
What device are you using? iphone 10
What firmware are you running ( aircraft, remote controller)? newest
What Go app version are you using?
just bought so not sure
Any modification?
its all a stock unit
Did you change anything or install any apps? nope
Do you have a video or pictures of the problem?
No I don't sorry
Any modification?
No I don't sorry
try to update the firmware to the latest version ... surely so it opens ... 😄Apart from the jokes, try to force a little and it should open.
The two mounting tabs in the top of the door have probably been messed up. Just try fiddling with the top of the door and visually looking for problems with the top of the door. Also, one of your things was if you had any go apps yet and just so you know, the mini se only works with DJI Fly app not Go.
Hope this helps!
elitewikipublishers
