MM camera works fine but lens is off center
Dbez1
107 Pilot
Ford City (N. of Pittsburgh), PA
My MM takes great video and stills, but I just noticed the lens itself is off center. Is there a fix for this or do I just ignore it? I never noticed it before. Thanks in advance for the help.image.jpg
My MM takes great video and stills, but I just noticed the lens itself is off center. Is there a fix for this or do I just ignore it? I never noticed it before. Thanks in advance for the help.View attachment 96685
That is the gimbal moved.
Turn on your drone
Point it facing you
Tilt the aircraft forwards and backwards, side to side
It should keep the camera pointing at you. That's how the camera stays steady while flying. If you're flying and your horizon is tilted there should be an adjustment in the settings.
I understand the gimbal movement, but what I’m referring to is the lens itself. The gimbal moves as it should, but if you look at the photo, the actual lens glass looks off center unless that’s normal??? Thanks ??‍♂️
3 dots upper right corner Fly app. Go to Control. Scroll down to Gimble calibration. Have fun, should solve your problem.
His issue is only that the lens is not in the center where he thought it should be. Calibration isn’t going to solve that dilemma.
Reactions: Capt KO
Stoopid me not paying attention to the photo. Rodger the lens not being in the middle. Worth a chuckle anywho. I was going to rag on you guys for giving him lousy information. Oops
geoff ellis
