MM2 Gimbal Issue
Hillbilly1236
BC Canada
Yesterday I downloaded the DJI Fly 1.2.5 app and can't use the "Allow Upward Gimbal Rotation" function. It's the first time I tried to enable the function since getting my new MM2 a couple of days ago. I've tried setting it when the AC is grounded and when it is in flight and it doesn't work either way. The function shows in the app as a gray color and when I try to slide it to the right nothing happens. Any pointers as to what I should try next.
Turns out this is not a slide!!!! Instead of touching the button on the left and sliding it to the right, you simply touch the right side of the slide. Seems weird to me to have a slide that doesn't slide. Why not have an on or off switch?
This took me a long time to figure out ....... maybe because I am not up to date with technology. In any case I hope this helps someone else.
gauravsaxena
