Moisture in Mavic Pro
lx_fabiano_xl
Hi guys, i'm have one problem with camera in Mavic Pro .. After fly for 5 minutes my image was gets blurry .. anybody can help to solve this!
i realise it's happen only when have start cooler work.. any idea ??
If you can determine it is a result of internal moisture it may be hard to remove if the lense element is sealed, I have no idea if it is but Thunder will certainly know..
having said that there are a couple of what should be harmless things you can try.
First get an air tight container like tupperwear or similar that will fit your drone and then some .
A large pan type of container is best. put about 1/2 in of this stuff in the bottom of the container set you Mavic on top and close it up. The Damorid sucks up moisture like nothing you have ever seen.
If tha is too aggressive then get som everyday Uncle Ben's or similar white rice fill the containe as above and seal in the Mavic. Rice will absorb moisture very effectively but not like damp rid.
the other element you can use is Silica gel you know those little packets that you get with electronic equipment. you can buy a jug of it on Amazon.
best of luck
mikemoose55
https://www.walmart.com/ip/DampRid-...Tm8AySoKXlrUimwTVNF6Tv0FsqzwADzcaAriHEALw_wcB
https://www.amazon.com/s/?ie=UTF8&k...&hvtargid=kwd-91005136&ref=pd_sl_28i0g2zxr3_e
best of luck
mikemoose55
Amazon.com: silica gel
ok mikemoose55 I'll try the rice first ... lol
ervinpl71
