Do the Epson Movario BT-300 glasses work with the Smart Controller? My friend is getting a set for his Mavic Pro. I would like to get a set too, if it will work with the SC.
So no, BT300 will not work with the Smart Controller afaik.Do the Epson Movario BT-300 glasses work with the Smart Controller? My friend is getting a set for his Mavic Pro. I would like to get a set too, if it will work with the SC.
Thanks for adding your thoughts. So much to think about. I guess I will have to see how my friend likes the BT-300 and see how it works. Then make some decisions based on that. I was thinking of the BT-35E to keep all the connections simpler, one of the reasons for getting the SC in the first place.Yes. The 35E is the one for the smart controller (takes the HDMI input). I have the BT-300 with the standard controller. I would suggest finding a standard controller and getting the BT300 unless you have another use for the glasses and HDMI. I say that because it seems to be a waste of the SC main feature- a great screen. You will also likely find it more intuitive to interact with the GO app and change settings using the track pad on the BT300, otherwise you will need to look down which defeats the purpose of the glasses to a large extent.
Thanks for letting me know. I was not aware of that. Now that you mentioned it, I do remember reading something about that in a post a while ago, but it really did not register at the time.
