Mp2Zoom camera faces off left ,wont center on its own
DannyDieHard
Live Oak FL U.S.A
Ok like yall see in the picture , once I power up ,the whole start goes good. But cam does the up down right left and center off set to the left. I can center on the app with my finger I can point the cam where I want it to look ,it zooms in and out. it looks up down evrything good so I lock it in fpv when I fly , but let's say on active track it looks off set again like it thinks the center is that way so it's on a slanted angle flying and obviously obstacle avoidance wont work correctly since the front is looking right and the cam is looking left. I have turned gimbal screws and plate to all 3 positions and still the same thing. I bought this mavic and it wasnt flying because of error 200, I changed gimbal and flex cable amd ribbon cable and it flies but it just won't recenter. I'm downloading the assistant to try and calibrate but how can I reflash it?
Have you try it with remote control?
click on 3 dots and try to calibrate?
Yes I have tried it all , except the assistant, I cant seem to find the one for the MP2Zoom ,
But yeah I tried calibrating with the mavic upside down. Facing down side ways I tried evrything I read on some ones post here about it but still hasnt figured how to fix it. Who else is having this issue ?
Try this page:
Ok I got the assistant finally downloaded but now while trying to figure out the camera facing forward I think I must have changed a setting which stops the camera from zooming in and out with the dial and it only like auto focus's slot like evry minute it it zooms in a little and back till it focuses. Is there a setting that does that ? Cause I cant zoom in with the app either it just keeps focus thing on it's own
And the assistant when I plug in it tells me the firmware is not right and needs to update I go to update and it fails the updates and when I tried to calibrate the gimbal and camera it stays stuck on the instructions step 4 of 4 amd the start calibrating button doesnt light up for me to click it. The most advanced drone I have and the one with the most technical problems
Try this page:
Heraklit0469
