Muti charger for Mini 2
Will multi charger Yx from Mini 1 work with Mini 2?
That is an interesting question. I suspect it will work because the connectors don't attach to the larger body of the battery but only plug into the flange where the contacts are. I have the Yx separate adapters for the MM1 which I think connects the same way. I like those a lot because I could/(can?) charge batteries simultaneously rather than sequentially in the DJI battery bank and are tiny so they can be taken anywhere and used anywhere there is a USB charger.
djipilot55
