My Way of Creating Waypoints for My Mavic 3 Classic
rexster1505
Texas
So, I've been a user of Litchi since my Phantom 4 Pro. Used the waypoint flying a lot back then. Stopped flying for about 3 years and times had changed. New DJI consumer drones weren't able to fly waypoints except by "virtual sticks" which was unacceptable for me. Many times I'd lose signal from the Phantom 4 for up to 12 minutes and always breathed a sigh of relief when communication was re-established.
When I got my Mavic 3 Classic last year, I knew Litchi wouldn't work on it, but the DJI way of programming waypoints for an autonomous mission was many, many steps backward, and trying to set up a waypoint flight on the 5.5" screen on the RC Pro was just too tedious.
I've read of several web based flight planners that work, some free, some limited unless you pay a subscription for features that still don't measure up to the way Litchi, Litchi Virtual Mission and Google Earth all work together in creating and then flying the mission on Google Earth before an actual flight mission.
For the last week or so, I've wondered and thought about if it was possible to create a Litchi mission in the Litchi Virtual Mission app, import it into Google Earth then change the file structure from a .kml to a .kmz file that can be squirted into DJI Fly app as a waypoint mission like the web based solutions,
Today I started fooling around with Litchi Virtual Mission, Google Earth and my RC Pro/Mavic 3 Classic.
Since we're having a house built several block from our present residence, I've been sending up the bird for overflights to check on the progress of the build.Having a repeatable, consistent flight would be cool so this was my test bed.
So, I created a mission with two poi's and a 14 point waypoint mission, and tweaked it several times using Google Earth to check on camera angles, altitude settings, and then headings settings.
After I was satisfied, I then saved the flight as a .kmz file in Google Earth, then selected an existing waypoint file in the FLy app on my RC Pro. I copied the file name in a waypoint folder, re-named the Google Earth waypoint file to that file name that was copied, then inserted it into the folder that contained the original waypoint folder after deleting the original .kmz file.
The moment of truth had arrived. Turned on the drone, waited for sats, started up the waypoint feature, selected the proper file name and it was off to the races. Other than some slight differences in speed and camera angles, the flight was perfect and all I did was watch on the screen as the flight proceeded from take off to the RTH landing.
I'm happy,
I'm happy,
Interesting post. Perhaps quite a few people might appreciate a step-by-step 'tutorial'. I know I'd be interested to have one to read through.
I use some of the utilities on DJI Wes’ site to get very good results Litchiutilites.com
This Light Painting was done using these methods and a Mavic 3 Pro. Have a look at his site and you’ll find some handy utilities.
Russ
Impossible.
While both Google Earth Pro and DJI waypoints use a file with the KMZ extension, they are different file types.
A Google Earth Pro KMZ file is simply a compressed KML file. The KML file contains data using the Keyhole Markup Language developed by Google.
A DJI KMZ file is a compressed set of two files: template.kml and waylines.wpml. These files contain data using the Waypoint Markup Language (WPML). The WPML language is specific to drones.
In a number of my utilities I've written code to convert data between the two formats.
Russ
I second the use of Wes’ utilities to do what you want to do.
Chris
Reactions: DJ Wes
Impossible.
Ok I'll just keep on doing what I'm doing. What I described works
Reactions: jwilson
I'm happy,
I plan to try this also using my Mavic 3 Classic, l just haven’t spent time yet on the details as you mentioned. Thanks for the reminder post. :)
I'm happy,
This is just what I need. The DJI waypoint editor is so crappy. I will try this and let you know how it works out for me! Thanks a million! So do use the Litchi Virtual Mission app on Windows or Android?
Impossible.
I’m not doubting you, but how is this different than waypointmap.com?
In waypointmap.com he is generating a DJI-compatible KMZ file comprised of "template.kml" and "waylines.wpml" containing the WPML language for DJI drones. Waypointmap.com will work for DJI drones if you desire to create mapping missions.
A Google Earth Pro KMZ file contains a KML file with placemarks, lines, polygons, and optional animation commands appropriate for Google Earth.
DJI is notorious for using established file extensions for their own unique purpose. As a result we have two different types of KMZ files: one for DJI drones and one for Google Earth. This confuses some people.
Reactions: jwilson
Thank you for the explanation.
Other than mapping, you can also create standard waypoint missions with waypointmap.com.
already a while ago, I created a tutorial how to convert Litchi missions into DJI Waypoint missions using the litchi utilities:
maybe this helps
Interesting thread. I'm brand-new to mapping and never used Litchi in my previous flying. I subscribed to the WaypointMap.com service and am learning to use it now. Is Litchi superior?
Ah--I just watched your tutorial. Thanks for putting that together! Litchi appears to have a different workflow but might be worth learning as well.
in the meanwhile Dronelink (specialized for mapping) supports a conversion of a mapping into a DJI Waypoint mission, and can also export the mission as KMZ file. Only left to do then is to upload the KMZ file into the controller/DJI Fly app.
Dimension Drone AZ
