Great thanks, how about if it's a bit dull will the ND8 be no good?
A bit of photography school here which may help you...
You want your ISO to be set to 100 for best image quality
You want to get your shutter speed to around 1/50
ND filters reduce your shutter speed
Every time you halve your shutter speed you reduce the exposure by 1 stop.
ND filter numbers can be confusing. Each time you double the ND rating you reduce the exposure by 1 stop and go up 0.3 in density.
So...
nd2 is 0.3 or 1 stop
nd4 is 0.6 or 2 stops
nd8 is 0.9 or 3 stops
Etc etc etc
So with that in mind...
Without an ND check what your current shutter speed is and work backward from there.
E.g.:
When flying with no ND your shutter speed is 1/400
1 stop reduction is 1/200
2 stop reduction is 1/100
3 stop reduction is 1/50
So you need a 3 stop NF filter, (nd8)
When flying with no ND your shutter speed is 1/1600
1 stop reduction is 1/800
2 stop reduction is 1/400
3 stop reduction is 1/200
4 stop reduction is 1/100
5 stop reduction is 1/50
So you need a 5 stop ND filter, (nd32)
Hope that's not too confusing.
Same here that makes a ton of sense. Thanks Chris.Thank you that's the best explanation I've seen so far on this forum!!!
But then, when I turn home, to have the sun behind me isn't the previously appropriate ND filter going to be all wrong and too dark
You're right. There's no need for ND filters, even in Manual, not only in Auto.Is there any benefit in using ND filters for simpletons like me, running the camera in Auto? I gather not.
