Need One Screw! Argghh :(
Pabby1980
Hi all,
Any idea where I can find one screw for a Mavic Pro?
The cheapest I've found is 10 for a fiver which just seems like a waste.
It's for one of the little case covers/flaps that you need to remove to do the gimball thread replacement. I'll try and post a picture.
If the pic posts, it's the little bits of plastic next to the case I need a screw for.
I threaded one of them on removal. Oops.
Just use the screw that resides under that cover to hold the shell. It's not needed and although slightly bigger will serve the purpose and solve your problem.
Reactions: Pabby1980
Thanks. Which do you think is needed more, the cover or the screw you mention?
I ask because the cover itself doesn't seem overly important.....im no expert though.
The cover needed more to keep dust out of hinge mechanism. Screw under neath that holds top cover not needed.
attifko22
