Newbie needs help connecting controller to AIR
Julien62
Hi Folks,
It has been some time since I flew the AIR. I broke it out, charged everything up. Then I downloaded the latest version of DJI GO4 and couldn't get past connecting via WiFi. When I went to the devices WIFI to try and connect manually and the AIR network asked for a password???
Can you help
Thanks for reading my post
Julien
Might be easier to update the firmware via DJI Assistant 2 on a PC
Download Mavic Air version here
The best method is to connect the PC to your router/modem via a Ethernet cable as DJI Assistant 2 doesn't like wireless drop outs.
However it will work most times with the wireless connection.
the DJI Assistant 2 upgrade process is 30sec into the video
Reactions: Julien62
@lannes
I was able to update the firmware in the Air. It still won't connect to the controller.
I connected the controller to the PC and started DJ Assistant 2 to see if it might detect an update for the controller. Nothing.
Your help is much appreciated.
Julien
Hereafter there is the link to the 2 official modes to connect your controller to the Mavic Air.
Try with both of them, if you have not already done.
Reactions: Julien62
Also try reformatting the SD card in the PC
Reactions: Julien62
kaidoestech
