Newbie
Hi there & welcome to the forum 👋 :D
And as you're new I throw in my Newbie card below ...
Read the user manual ...the thick downloadable one, not only the quick start, download here --> https://dl.djicdn.com/downloads/Mavic_Air_2/Mavic_Air_2_User_Manual_v1.6_enIII.pdf
Power on in the right order ... First power on your RC & start the app ... after that, power on the drone (& do it on the spot you're going to take off from). Reverse order to shut down.
Preferably power on the drone keeping it horizontal in your out stretched hand (without watches, rings or other magnetic objects) … once the live view have turned up in your mobile device you can put it on ground for take-off. (This supports the point below …)
Before take-off ALWAYS ... add in one very easy check to avoid a really scary event coming from accidentally launching from a magnetic disturbed place with following flyaway at height in an uncontrollable circular or straight flight path. After powering on your drone, connected to your RC/app & placed it in the take-off spot ... but before lift-off, ALWAYS check that the drone icon on the map in your app is pointing equal in relation to other objects in the map as the drone does in reality ... if not, abort launch attempt, POWER DOWN & move away, power up again and repeat.
Keep well under the wind spec where you fly ... and please note that it's not only at ground, it's at the altitude where you fly. The winds up to 400ft are very different then on ground. Use for instance the UAV Forecast app where you can get a feeling about the winds on higher altitudes, but please note that it's forecasts we are speaking of, a bit of common sense is good to apply to that ... "better skip flying a windy day & fly more another".
Don't go & calibrate everything on a regularly basis ... why fix things that are working, it's just a higher risk that you by mistake calibrate your compass in a magnetic disturbed area & the drone goes haywire 10 meters up in the air. Calibrate IMU + compass according to user manual, keep away from magnetic things like cars, metal tables & reinforced concrete at take-off & compass calibrations. If the app recommend a compass calibration first try another launch spot on a far distance from the first ... if calibration still is recommended by the app do it, but only then.
Don't launch in a hurry ... wait until you have at least 8, preferable 10 locked satellites & wait for the lady voice announce that the Home point has been updated, check then on the map that it's in the correct spot. Learn how the RTH function works (it can work differently depending on scenario), don't set the altitude for that unnecessary high, look around were you are going to fly and set it to clear the highest obstacle, to high & the drone risks a blow away.
Seek up a large open place ... a soccer field, free of obstacles & people. Test off every function one at a time until you fully understand how it works & the logic behind, confirm through the user manual if needed. Fly low, slow & near. And don’t try to fly indoors before you exactly know what makes these machines fly stable … you only risk your interior & to damage your drone in the process.
Take the claimed control distance from DJI with a pinch of salt ... only doable out in the countryside completely free of WiFi disturbance & obstacles in between the Remote & Aircraft.
Don't rely 100% on the obstacle avoidance sensors ... they are good & handy to have to perhaps save you when making a mistake, but they can't see everything, especially thin branches & wires so don't think they will allow your drone to just bounce away from everything all the time. Also note that they need plenty of light to work properly, too dark & they will turn off.
The Pause button on the RC ... It's a handy one, it will stop all automated modes immediately (if you have GPS coverage). Place your thumb on that when you initiate an automated flight mode & be prepare to stop it if too close to a tree for instance.
Don't use the RTH button as a "panic button" it's usually the weakest mode of them all ... you will always have access to more power in the manual modes ... if slow against a bit to strong head wind, go for Sport mode, drop altitude & manoeuvre the drone home manually.
Learn the rules & regulation ... keep the drone within Visual line of sight & respect max altitudes, if you can't avoid going out of visual keep it at least in line of sight (unobstructed line between Remote & Aircraft even though you don't see it) so you don’t lose the connection.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Welcome to Mavic Pilots! :) Enjoy the forum! Thumbswayup
Hello from the Crossroads of America DroneAlone57.
Don't forget to swing by the FAA when you get the MA2 to register.
While you're waiting for delivery, might as well take the TRUST test and have a copy with you when you fly, If you haven't done it yet.
Good luck and welcome to the Forum. 😎
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
Depending on your kit, the application DJI Fly is what you'll be using; either installed on your phone/tablet or on your Smart Controller (RM500). There isn't really a manual for the app; but inside the Air2 drone manual there are sections that explain some of the app features. Dig into the manuals and read them cover to cover, it is well worth the effort.
Slup posted links, head to the download pages and get a head start. You'll be happy you did.
Also - there are laws around flying your new drone. Start with the FAA Trust test, get registered, and learn about any local laws (like it is virtually illegal to fly any drone in NYC).
Also - the B4Ufly app is very helpful:
Here's the FAA rule you'll probably be starting under:
And here's a link to a Community Organization you can join in order to have the basic rule set covered.
Reactions: Rchawks and slup
Thanks for the info
fiweli
