OA Obstacle Avoidance - Any hacks to increase ground-level speed
jeff-gts3Mz@
Wisconsin
I was curious if anyone found a way of keep Obstacle Avoidance ON, but increase ground-speed (e.g. 10ft AGL) when desired, for video below tree canopy.
Like other models, the M4P seems to be stuck going 10mph. I could situations where each 15, 20, 25, and 30mph would be desirable.
Of course, the other way would be to speed-up video in post-production.
What is the maximum speed in the Fly App that you've set for the mode you're flying in?
Are you seeing a different maximum speed when flying at 10' AGL than when flying at 100' or more?
Standard mode (44mph). Cine operates the same.
Yes, different maximum speed. At higher altitudes speed is at its potential.
For point of reference, the Air 3s operated the same.
You can turn OA to off and 10’ has full speed.
Reactions: MS Coast
Coronet Drone Werx
