PanoVolo - drone pano stitcher - 1.7.0 released
PanoVolo
Approved Vendor
Halifax NS Canada
Site
www.panovolo.com
A new version is available for Windows and macOS.
Main highlights:
1. The new "fill sky" function allows the zenith hole that most drones leave in 360 panos to be filled with interpolated data. Saves the trip to PS for post-processing. Also works in batch mode.
2. Supports DJI Osmo Pocket panoramas
3. UI was translated to main European languages
Full release announcement:
Main highlights:
My most obvious question...Since I have already purchased the software, can I upgrade free?
Dale
Miami
Dale
Miami
Hi Dale,
Yes of course, upgrades are free and your current license works, you don't need to activate it again. Just replace the app with the new version and you are good to go.
Reactions: mavictk
Hi Dale,
Can you please advise how to install upgrade? Can you send me a link to install and upgrade?
Dale Davis
[email protected]
I see it’s Mac or PC.
It can work with the raw DNGs, if I make Lightroom adjustments before importing to Panovolo does it take that into account or just process the orig DNG with no corrections ?
If that’s what it does, is there any advantage to make making corrected Tiff files, i.e. color, exposure, lens, corrections, etc, .first and then using PV to stitch?
it takes original dngs. LR adjustments are in the proprietary format.
However, you can export DNGs from LR (and these will have your edits applied to them) and use them as an input for Panovolo.
Another workflow and in my opinion a better one is to stitch from original DNGs first, and then postprocess panorama TIFF. Original DNGs have no contrast or sharpness applied and are easier for Panovolo to exposure match and blend.
Reactions: jephoto
I got to say, I am impressed with PanoVolo 1.7 been playing around with the 137 pics from the air3 and have fiddled with many diffrent applications in the past and this is by far the most clean experience. (Happy with how it does the sky for the most part too)
Tiny planet I took and was messing around with as one example.
Or
I bought the application last night for 29 usd after playing with the trial with the watermarks and I got to say it may be worth it for using the 137 pic 360.
Just my opinion the sofrware seems a bit buggy (willing to speak a bit more to dev for that if intrested) but overall happy, will post over in pics too as the pic is cool high-level but the difference is the zooming in on it vs normaly tiny planets.
-Venny
I am typically skeptical of software hawked on forums, especially by the company, but I have to say, this one delivers. For the price and speed, it's pretty earn good, IMO.
Reactions: VenomXts
Purchased this as well last week. Only used it once since installing it, but looks promising. Mavic 3 Classic
Ok, odd problem, I have been using the batch processing on old pano folders and it has been working great and outputting.jpeg but now its outputting .Tiff and or the life of me im not sure why or how to change it back.
How do I get fill sky to work? I am making rectilinear panoramas from nine 3x3 wide angle shots on a Mavic 3 Pro. Fill sky indicates it is working but does not touch the gap in the top center of the panorama (nor the one on the bottom).
if your input is JPEGs your output will also be JPEG. If your input is DNGs, your output will be TIFF. You can control this with "Prefer JPEGs / Prefer DNGs" selector.
That was it, for some reason on a air2s inwas only taking. Dng for Panos but for my air3 it's jpegs.
Do have one other question any plams for gpu processing instead of cpu in the future?
Thanks
Sean
osje
