Please help!
JimSams
Louisville, Ky
Problem? Replaced camera, took two cameras to get a picture, now I am getting vision system errors and cant calibrate on the Assistant since they are not communicating.
Was unit in a crash? Yes
What have you tried so far? Removed every outer panel and checked for loose connections, as i said Ive replaced the gimbal assembly twice.
What device are you using ( iphone , ipad, Samsung , etc)? iPad
What firmware are you running ( aircraft, remote controller)? MP .400 RC .500
What Go app version are you using? DJI GO 4
Any modification? (if so what) None
Did you change anything or install any apps? (if so what) only the gimbal assembly
Do you have a video or pictures of the problem? (if so post link) None
BigPapa98
