Mini 3 Plover Scar Lighthouse & Hitchcock's "The Birds" !
Paul Iddon
Preston, UK
On the south edge of the Morecambe Bay near Glasson Dock, at the mouth of the river Lune sits a modest but beautiful Plover Scar Lighthouse. Built in 1847 it has seen better days but still makes an enjoyable visit it and is the subject of many photos.The lighthouse consists of an 8-metre-high (26 ft) white conical stone tower, with a black lantern and twin galleries, built on a rock ledge that is uncovered at low tide.
With a focal height of 6m above sea level, the light can be seen for six nautical miles. Its light characteristic is made up of a flash of white light every two seconds.The lighthouse was built in 1847, as the lower light of a pair of leading lights, and is therefore also called the front or Low Light. The rear or High Light, known as Cockersand Lighthouse, once stood next to the Abbey Lighthouse cottage on Slack Lane. It was a square wooden tower supported by angled wooden struts. The leading lights helped ships navigate into the Lune estuary, to reach Glasson Dock and then onwards via the Lancaster Canal to the port of Lancaster, with Plover Scar marking the rocky outcrop at the edge of the deep water channel into the estuary. Both lighthouses were equipped with a pair of paraffin lamps mounted in parabolic reflectors, each displaying fixed light seawards. In the early 1950s electric lamps replaced the oil lanterns; at the same time the wooden High Light was replaced by a metal framework tower. By the end of the decade the lights were fully automated; the High Light was deactivated some time after 1985 but Plover Scar remains active.
Prior to automation the lighthouse keepers and their families lived in the lighthouse cottage next to the Cockersand lighthouse. Originally the accommodation was incorporated into the base of the lighthouse structure, but was later replaced by the cottage that still stands today. The keepers maintained both lighthouses, walking across to Plover Scar at low tide. The Raby family kept the lights for nearly a century, until 1945 when it was taken over by the Parkinson family. Mrs Parkinson was filmed maintaining the lights in 1948 by the British Pathé news organisation.
In March 2016, the lighthouse was badly damaged when it was struck by a passing commercial vessel, which was navigating its way at night to Glasson Dock. The collision dislodged the upper part of the tower, and although the light continued to operate, substantial reconstruction of the tower was deemed necessary. The subsequent repairs which started in September 2016 meant the stone tower had to be partially dismantled, with the lantern removed for renovation. Over 200 stone blocks from the dismantled tower were taken to a work site on the beach and numbered so that they could be reused when the light was rebuilt. The works also revealed that an extra outer layer of stones had been built around the tower, which had been added in 1856 to create an outer walkway. Although the works were delayed by various factors, they were finally completed in May 2017.
Paul.
Another good video. what was all that shaking in the beginning?
Reactions: Paul Iddon
Overall, the video was really good. I will say some of the effects you added were 'different.' The opening scene, I had to look away, keeping the video in my periphery, until it was done. I understand creative license and expression. It certainly is creative.
Thank you both.
The opening was really because the soundtrack had the sounds of wind etc, and the sea breeze was there as I flew, so I added the fun element of the the drone shaking in the wind!
Paul.
zotacreborn
