Problem with flicker and jerkey video.
TNielsen
Denmark
I just took over a Mavic pro company drone to fly in the company. I've been out with it a couple of times and find that there is a lot of flicker and tiny hiccups in the video that is being filmed. Flying with my own Mavic Air is all smooth. I have a sandesk extreme pro SD card in it, so I don't think it is there. At first I thought it was the sun and the propellers, but the last video I took was a cloudy evening. Since this is a used Mavic I have taken over, I would like to reset all settings so that all video modes are reset. What do you think I should do?
Here is a link to youtube, where I was out trying and testing yesterday evening. Problem is also on the original fottage from SD card
https://youtu.be/ZFgcIb_kPM0
Was the original set to 4k - wonder if in the conversion to 1080 causes it - when’s donwload original to your mobile device is it similar
Reactions: Thomas B
Thanks a lot. Have changed from mov to mp4 format, and tryed another SD card.
Problem Solved... Thanks again.
Do you know which one solved it?
Switching to mp4? Or a different sd card? Which one?
I’m having similar issue.
Thanks
Mike
Hi
Not 100% sure, but think that the switch to MP4.
The SD card was the" SanDisk Extreme Pro 64GB" and the one i got the good video with was a slower "SanDisk Ultra 64GB", so i dont make sence if thats the problem
BigSmoke
