Propellers
  • Thread starter Thread starter Deleted member 161691
  • Start date Start date
@Nequick36 ,no sorry to tell you that the props are different, and not only that ,the Screws that hold them on are different as well ,in thread size and length, unfortunately they are not interchangeable
You could try the likes of Heliguy Mavic Mini Propellers , but I do not know if they do international posting nor do I know their international postage rates.
Some other Europeans on here might know of shops that are closer to you.
The other thing that occurs to me is something like these For -DJI Mavic Mini 2 Motor Cover Cap Drone Dust-proof Engine Protector Guard | eBay
but you would need to find screws to clamp the plates to the motors. It looks as if the screws supplied with them are for Mini 2 motors and as Old Man Mavic noted the screw threads in the Mavic Mini motors are incompatible Mini 2 screws. Also if a sub 250g weight is of importance the weight of these caps would probably put your drone over weight.
Alternatively if you know a good machinist/lathe-operator they could perhaps make you up a set of adapter screws
Ugh, what about low noise propellers?
Does they make any other thing expect low noise, like effect flying or something?
Reactions: old man mavic
@Nequick36 there are several none OEM props that purport to be suitable for the MM ,but to be perfectly honest with you although they might fit, their quality is an unknown ,and as along with the battery the props are the most important things that keep the drone in the air ,and any failure would have only one effect, and i am sure you know what that is ,when you look on the internet read the small print of the product, does it say genuine DJI props for the MM ,or that they are suitable for the MM ,if it is the latter they are probably lookalikes ,
I bought a crashed mavic mini, when I got it the props were all after-market and a pile of ......
Some were stiff on their pivots. i.e. poor bore moulding or too small a bore and some bores were off centre. I can't help but wonder if they were part of the reason for the crash.
Of course not all makes of after-market props are such but I too would stick with DJI props.
John2205
