Propellers
Max Headroom
England.
I had my first minor crash with the mini 3 last time out as a gust of wind blew it off the car roof just as the props stopped rotating fortunately the ground was soft so the damage was limited to one prop, when i got the new one out of the bag i noticed for the first time that the orange tips are made of rubber unlike the props i had for the mini 2 SE which were solid, the rubber tip had torn on impact but it wasn't easy to spot so i will check more thoroughly for similar damage when doing pre flight inspections in future.
Is this type of prop used on many DJI drones and is it the reason the mini 3 is much quieter that the Mini 2?
I've noticed them on quite a few of the newer drones, they're a 'safety feature' that just happened to alter the sound generated by the spinning blades.
The older style of rotors would give you a really nasty cut if you got your fingers in the way, hence the introduction of the silicone end sheath, the worst for chopping up your fingers are the MAS props - which bear a striking resemblance to one of those vicious little double ended blades you find at the bottom of an electric spice grinder.
Love the idea of using my drone to help with the gardening!! 😂
Could also save a bob or two with dog grooming.... 😬.... and the cat that keeps crapping in your herbaceous border would be in for a nasty surprise as well.
  • Haha
Reactions: Mrktn
Or the waxing salon for those that don't like the wax ;)
Would that be a bit like the thing K-Tel used to sell that shaved the bobbles off your jumpers?... need some fine prop cages for that... But if they're going to market it... the problem then becomes what do they call it? DJI Bushwhacker?
Reactions: Max Headroom
fr legends apk money
That’s a lucky escape! Yes, many newer DJI drones use rubber-tipped props to reduce noise and improve aerodynamics. It’s likely a key factor in the Mini 3’s quieter operation.
Did he really think no one would notice his driving simulator spam link, what a dumbass.
Thanks for sharing your experience! It’s always helpful to hear about real-world crashes and the durability of different prop designs.
Checking for damage during pre-flight inspections is definitely important, especially with rubber-tipped props.
As for your question, yes, some other DJI drones use similar rubber-tipped props, which can contribute to quieter flights compared to older solid props.
FR Legends Mod Menu
Reactions: Rchawks
KenBrackin
