Question about djgo vrs go4.
laura schlenker
Ok. I still am running the original go3 app that I've had every since I got the mavic.Im getting goggles and Crystal sky. I'm assuming when I get the CS. It will have go 4 already so I will be forced to go to Go4? My question is will I run into Any of the restrictions that people are trying to avoid or is it only the firmware that will cause the unwanted restrictions. I'm on .900 firmware.
Yes. The restrictions are based on your firmware. Roll back your firmware to .700 or .400 to avoid those restrictions.
Thank you im not sure how to do that at all! So if inwere tp instal go4 on my tablet right now and delete the old go 3 app, my bird would act exactly the same? The reason I want to stay on .900 firmware is i was told it works freer with the goggles.
Firmware .700 works perfectly well with the goggles. Check here to learn how to rollback your firmware.
How to rollback Mavic firmware
It's not difficult and well worth the effort (if you don't want the restrictions or wish to have the ability to modify your parameters).
rejuwa
