RC cable for IPad
Bellaflys2016
Can someone tell me if you can connect IPad Pro to RC with WiFi, Bluetooth or where I Can get a longer RC cable to connect to it?
You can use WiFi to connect to your drone but have limited range. See link below on how to do this.
I would go for a longer cable which you can pickup from Amazon or anywhere on the net. I would say a 12 inch cable would suitable. Also I would not use the micro USB port on the side of the controller but use the standard one on the bottom, which works. Make sure to remove the side connector if using the USB port on the bottom.
Hope that makes sense;)
proya12
