RC Pro HDMI Out Camera View
Parkerjh
Boston, MA, USA
Using RC Pro with Mavic 3. I recently had to send my RC Pro in for some loose antennas. Now, the Display > HDMI menu in settings no longer lets me choose "Camera View" for HDMI out. My only choice in that submenu is resolution.
I'm 99% sure that's where the setting was located to choose camera view.
Am I remembering incorrectly or is this no longer an option with an RC pro?
I think what you are remembering is the option in the flight app.
In DJI Pilot 2 for example:
  1. Click on the top right three dots
  2. Click the "HD" icon
  3. Next to "Video Output Type", change "Duplicate Screen" to "Camera View"
Reactions: DARKSeifer
Yes, once you connect the HDMI, inside the fly app go to transmission panel, you will be able to change to video feed only.
And to change the resolution, you do it through the settings panel on the controller itself, outside the app.
Also, the drone will transmit at the framerate you set to record, if you set 4k/30fps, it will transmit at 30, if you select 60, 60, so for a better flight experience set 60fps.
Reactions: PAW
Yeah, weirdly enough, this option went away. I replaced the cable with a new cable and that seemed to work. No idea why the cable made a difference, but it is working now! thanks everyone
Reactions: PAW
marcusjohn3684
