RC2 Controller and DJI Air 3S
TexasStar15
Austin, Texas
I bought a RC2 controller for my Air 3S. I've got it activated and linked to the aircraft. Went it to check for updates and there are updates. I downloaded it and when I go to install it gets to 40% and fails. I've restarted aircraft and restarted controller and same thing. Can anyone tell me how to get past 40%, I feel like I'm doing something wrong but have no idea what. Thanks guys!
Are you using assistant 2?
Gotcha you need to Download the DJI Assistant 2 From the DJI website and install it on your P.C.
Dowload and install
Plug the controller into your PC with the appropriate cable
Open DJI Assistant 2 and follow the prompts to update the Controller.
Dowload and install
I will give that a try, thanks!
Reactions: Cafguy
Reactions: Cafguy
if you need help let me know REMEMBER to choose the windows Download ( if you are on a windows machine)(mac is default in my example)
DJI assistant is used when a wireless update will not work or is not possible. by installing the assistant you will be able to directly update the controller once its plugged into the Computer.
Somehow I got it to update with the DJI Fly app. It had something to do with my old controller I think. Plugged it in and updated then the new RC2 udated. Not really sure how but problems solved. Thanks again for your help!
Reactions: Cafguy
northernmonkeyx
