And how can i fixed it bro?Welcome to the forum from the deserts of Arizona! W.
get the drone fixed before trusting it in flight.
Okay thanks bro. So i can take it normally to fly and there will be no problem?The 1cm of play should be okay, as long as you’re not hearing any prop strikes anywhere. You may want to watch DJI Drone Service’s YouTube video on replacing your own arm to see if you can tighten it yourself.
And welcome to the forum, by the way!
I AM FLYING with the mavic only sometimes. So it will be okay in flight?While you may get by without repairing your aircraft it is always best to fix it properly. Would you want to travel on an airliner with a damaged wing or would you want it repaired?
Can you send me picture please how ?welcome to the forum, i would not fly it as it is ,if you loosen the two screws a small amount where the arm attaches to the body of the drone you might be able to get it back to where it was before the crash
