While I'm here I have another question. I have a few packs that are old 200+ cycles. When it's cold the cells are out of balance and they're beginning to swell. I won't fly with them I'm afraid they could fall off. But they do function. I have a few other packs/cells with an error. The battery icon turns red and there are no cell voltages. They are like new with only a few cycles. I can also fly with them, but no idea what percent, or if there is a bad cell. What I'd like to do is swap the new cells into the working old BMS. I've seen a few do it in YouTube videos. I have some empty battery cases from Aliexpress to make assembling easier. Is this difficult? Any hints?
I see you should keep the power connected to the BMS that is currently working. Then you don't have to reset them?
I also have a few that will not turn on. When I press the button or connect charger. There is a way to reset these? Then I can test the cells on the ground.
Thanks!
Thanks!
