Remote controller interchangeability
_seven
Philippines
Hello,
I got 2 sets of Mavic 3, one has the RCpro, while the other one has the DJI RC , is it possible to have the controllers interchangeable with each drone? reason being that im trying to spread out the "mileage" for both birds and I do prefer to use the DJI RC for regular shoots then just use the RCpro for livestreams.
it can be somewhat done with the old DJI Smart Controller (which I still have with my mavic 2 zoom and 2 pro) where I could just swipe down and select change aircraft via app - no need to go to the linking process
thanks
yes you can swap between them. If you swap at some point after 5(?) or more flights you may be prompted to bind the controller but that's not a big deal. When I travel with my Mav 3 and don't bring my Mini 3Pro I use the RC controller for its' convenience.
Reactions: _seven and ssvdh66
If you have Care Refresh, you will need to bind the craft to the controller each time. If you don't, Flyaway will not be covered. Not a big deal, just something else to remember to do.
Mamanov Ramazan
