Remote not connecting to mavic pro 2 even when i press link button on the side of mavic it dont light up
My mavic pro2 won't connect to remote ant when I press link button on side of mavic it doesn't light up
The Aircraft is linked to the Remote Controller before it leaves the factory. You should only need to re-link when using a replacement controller.
Reactions: Thomas B
Have you tried both methods of linking, how far do you get with each one ?
Hi, has anyone found a solution to this issue as I too face the same problem of link button led not lighting up
I was having the same problem after I updated the new firmware I called support and they said my iPhone 11 was not compatible at this time with the new update they said a new update would be coming soon
Jrwooley4
