removing battery
they do seem to be a bit tight when they are new ,you will find they get easier after they have been removed a few times ,same with the charging hub in the fly more package
I find it easier to flip the drown over and remove it while turned upside down. Your thumb will press down on the release mechanism, and allows the battery to slide out easily.
Reactions: Gagey52
just made this to remove my batteries from the M2, I used the motor clamp from my P3P glued and taped a piece of ally on ,job done, battery comes out easy now using this.
I think you'll find that the battery comes out a lot easier after a while so no need for a clamp, I only used mine for about 6-7 times before I was able to pull it out eaiser
My battery comes out easy, I can't get my finger to grab the top lip. My hands don't work well :)
stephy_gl
