Replaced Gimbal Now Wont Calibrate
justinmercer
Orillia Ontario
Hey I replaced the gimbal, and this is what it is doing now? Check Out The Youtube Videos Below
Tell us how you calibrated it step by step
Did that member calibrate the gimbal or simply use some software to match the numbers in order for the gimbal to work? or both?
I am thinking that this member got the numbers working BUT did not calibrate the gimbal itself- just an Idea. you may want to see if you can calibrate it using python if you need instructions for this I can post them or just go to YouTube.
P.S. Yorkshire----I have not heard from the guy that has the 500 dollar software...BUT that sounds super cheap for a RepairTool clone.:confused:
For some reason I have the impression it might have been an add-on to existing software rather than a stand alone thing but I could be wrong there.
Dimension Drone AZ
